Saltar al contenido principal
Sony BDP-S3500 Wi-Fi Module Replacement
Qué necesitas
  1. Sony BDP-S3500 Wi-Fi Module Replacement, Front Panel: paso 1, imagen 1 de 2 Sony BDP-S3500 Wi-Fi Module Replacement, Front Panel: paso 1, imagen 2 de 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Wi-Fi Module Replacement: paso 2, imagen 1 de 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Wi-Fi Module Replacement: paso 3, imagen 1 de 2 Sony BDP-S3500 Wi-Fi Module Replacement: paso 3, imagen 2 de 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Wi-Fi Module Replacement, Port Board: paso 4, imagen 1 de 2 Sony BDP-S3500 Wi-Fi Module Replacement, Port Board: paso 4, imagen 2 de 2
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
  5. Sony BDP-S3500 Wi-Fi Module Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
  6. Sony BDP-S3500 Wi-Fi Module Replacement: paso 6, imagen 1 de 1
    • Remove the port board from the device.
  7. Sony BDP-S3500 Wi-Fi Module Replacement, Wi-Fi Module: paso 7, imagen 1 de 1
    • Remove the white ribbon cable connecting the Wi-Fi module to the motherboard by gently pulling it out.
  8. Sony BDP-S3500 Wi-Fi Module Replacement: paso 8, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the 7mm screw from the Wi-Fi module.
  9. Sony BDP-S3500 Wi-Fi Module Replacement: paso 9, imagen 1 de 1
    • The Wi-Fi module can now be safely removed.
Conclusión
Bushra Banuso
Miembro Desde 01/22/20
97 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 366
