Saltar al contenido principal
Sony BDP-S3500 Motherboard Replacement
Qué necesitas
  1. Sony BDP-S3500 Motherboard Replacement, Front Panel: paso 1, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement, Front Panel: paso 1, imagen 2 de 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Motherboard Replacement: paso 2, imagen 1 de 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Motherboard Replacement: paso 3, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement: paso 3, imagen 2 de 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Motherboard Replacement, Disk Drive: paso 4, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement, Disk Drive: paso 4, imagen 2 de 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Motherboard Replacement: paso 5, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Motherboard Replacement: paso 6, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement: paso 6, imagen 2 de 2
    • Carefully lift and slide the disk drive out of the casing.
  7. Sony BDP-S3500 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Remove the ribbon cables by holding onto the cable and gently pulling straight up.
  8. Sony BDP-S3500 Motherboard Replacement: paso 8, imagen 1 de 3 Sony BDP-S3500 Motherboard Replacement: paso 8, imagen 2 de 3 Sony BDP-S3500 Motherboard Replacement: paso 8, imagen 3 de 3
    • Use the Phillips #2 screwdriver to remove three 9mm screws securing the motherboard to the case.
    • Remove one 5.5mm Phillips #2 from the back of the case near the ports.
  9. Sony BDP-S3500 Motherboard Replacement: paso 9, imagen 1 de 1
    • Slide the motherboard away from the back of the case and then lift up to remove.
Conclusión
Una persona más ha completado esta guía.
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 598
