Saltar al contenido principal
Sony BDP-S3500 Motherboard Replacement
Qué necesitas
  1. Sony BDP-S3500 Motherboard Replacement, Front Panel: paso 1, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement, Front Panel: paso 1, imagen 2 de 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Motherboard Replacement: paso 2, imagen 1 de 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Motherboard Replacement: paso 3, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement: paso 3, imagen 2 de 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Motherboard Replacement, Disk Drive: paso 4, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement, Disk Drive: paso 4, imagen 2 de 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Motherboard Replacement: paso 5, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Motherboard Replacement: paso 6, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement: paso 6, imagen 2 de 2
    • Carefully lift and slide the disk drive out of the casing.
  7. Sony BDP-S3500 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 Sony BDP-S3500 Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Remove the ribbon cables by holding onto the cable and gently pulling straight up.
  8. Sony BDP-S3500 Motherboard Replacement: paso 8, imagen 1 de 3 Sony BDP-S3500 Motherboard Replacement: paso 8, imagen 2 de 3 Sony BDP-S3500 Motherboard Replacement: paso 8, imagen 3 de 3
    • Use the Phillips #2 screwdriver to remove three 9mm screws securing the motherboard to the case.
    • Remove one 5.5mm Phillips #2 from the back of the case near the ports.
  9. Sony BDP-S3500 Motherboard Replacement: paso 9, imagen 1 de 1
    • Slide the motherboard away from the back of the case and then lift up to remove.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 483
