Saltar al contenido principal
Sony BDP-S3500 Disk Drive Replacement
Qué necesitas
  1. Sony BDP-S3500 Disk Drive Replacement, Front Panel: paso 1, imagen 1 de 2 Sony BDP-S3500 Disk Drive Replacement, Front Panel: paso 1, imagen 2 de 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Disk Drive Replacement: paso 2, imagen 1 de 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Disk Drive Replacement: paso 3, imagen 1 de 2 Sony BDP-S3500 Disk Drive Replacement: paso 3, imagen 2 de 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Disk Drive Replacement, Disk Drive: paso 4, imagen 1 de 2 Sony BDP-S3500 Disk Drive Replacement, Disk Drive: paso 4, imagen 2 de 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Disk Drive Replacement: paso 5, imagen 1 de 2 Sony BDP-S3500 Disk Drive Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Disk Drive Replacement: paso 6, imagen 1 de 2 Sony BDP-S3500 Disk Drive Replacement: paso 6, imagen 2 de 2
    • Carefully lift and slide the disk drive out of the casing.
Conclusión
V W
Miembro Desde 01/22/20
197 Reputación
1 Guía escrita
Equipo
Un comentario
Hello, great guide thank you. How do you go about finding the correct replacement drive?
Andy Day - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 394
