Saltar al contenido principal
Sony Alpha NEX-3N Lens Release Button Replacement
Qué necesitas
  1. Sony Alpha NEX-3N Lens Release Button Replacement, Getting Started: paso 1, imagen 1 de 2 Sony Alpha NEX-3N Lens Release Button Replacement, Getting Started: paso 1, imagen 2 de 2
    • Remove battery and card
  2. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 1: paso 2, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 1: paso 2, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 1: paso 2, imagen 3 de 3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 2: paso 3, imagen 1 de 1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 3: paso 4, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 3: paso 4, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 3: paso 4, imagen 3 de 3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N Lens Release Button Replacement, LCD assembly: paso 5, imagen 1 de 2 Sony Alpha NEX-3N Lens Release Button Replacement, LCD assembly: paso 5, imagen 2 de 2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N Lens Release Button Replacement, LCD Assembly: paso 6, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, LCD Assembly: paso 6, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, LCD Assembly: paso 6, imagen 3 de 3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N Lens Release Button Replacement, The LCD assembly: paso 7, imagen 1 de 1
    • The LCD assembly
  8. Sony Alpha NEX-3N Lens Release Button Replacement, Keypad: paso 8, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, Keypad: paso 8, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, Keypad: paso 8, imagen 3 de 3
    • Lift the keypad.
    • Detach FPC
  9. Sony Alpha NEX-3N Lens Release Button Replacement, Screws: paso 9, imagen 1 de 1
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  10. Sony Alpha NEX-3N Lens Release Button Replacement: paso 10, imagen 1 de 2 Sony Alpha NEX-3N Lens Release Button Replacement: paso 10, imagen 2 de 2
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  11. Sony Alpha NEX-3N Lens Release Button Replacement: paso 11, imagen 1 de 1
    • Remove that part whatever called, by sliding it backwards.
  12. Sony Alpha NEX-3N Lens Release Button Replacement, Screws: paso 12, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, Screws: paso 12, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, Screws: paso 12, imagen 3 de 3
    • 1 ST1.7x5
    • 2 ST1.7x5
    • 1 M1.4x3.6 black
  13. Sony Alpha NEX-3N Lens Release Button Replacement, The Grip: paso 13, imagen 1 de 2 Sony Alpha NEX-3N Lens Release Button Replacement, The Grip: paso 13, imagen 2 de 2
    • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
    • Pop the grip off. From back, push to the right, then it flies forward.
  14. Sony Alpha NEX-3N Lens Release Button Replacement, More Screws: paso 14, imagen 1 de 1
    • Remove 2 M1.4x2 black screws
  15. Sony Alpha NEX-3N Lens Release Button Replacement, Pop the Shielding Cover: paso 15, imagen 1 de 2 Sony Alpha NEX-3N Lens Release Button Replacement, Pop the Shielding Cover: paso 15, imagen 2 de 2
    • with caution and patient.
  16. Sony Alpha NEX-3N Lens Release Button Replacement, One More Shield: paso 16, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, One More Shield: paso 16, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, One More Shield: paso 16, imagen 3 de 3
    • 1 M1.4x3.6
  17. Sony Alpha NEX-3N Lens Release Button Replacement, Detach 7000 FPCs: paso 17, imagen 1 de 1
    • Sensor power, flip
    • Sensor signal, flip
    • Shutter, pull
    • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
    • Whatever, pull
    • Whatever, pull
    • Shutter charger motor FPC, (backside, pull out)
  18. Sony Alpha NEX-3N Lens Release Button Replacement: paso 18, imagen 1 de 1
    • Flip the Mainboard up
    • Pull out one more FPC
    • Discharge then desolder 4 wires.
    • CAUTION! Possible high DC voltage >300V
  19. Sony Alpha NEX-3N Lens Release Button Replacement: paso 19, imagen 1 de 1
    • Lift main board and plastic frame with flash capacitor.
  20. Sony Alpha NEX-3N Lens Release Button Replacement, FPC cables: paso 20, imagen 1 de 1
    • Detach sensor Power (L)and Signal(R) FPC
  21. Sony Alpha NEX-3N Lens Release Button Replacement, Screws: paso 21, imagen 1 de 1
    • Remove 3-4 ST1.7x5 screws
    • Remove 1 M1.4x5 screw
  22. Sony Alpha NEX-3N Lens Release Button Replacement: paso 22, imagen 1 de 2 Sony Alpha NEX-3N Lens Release Button Replacement: paso 22, imagen 2 de 2
    • Remove 4 ST1.7x5 screws for the E-Mount
    • Remove mount metal ring
  23. Sony Alpha NEX-3N Lens Release Button Replacement, E-Mount: paso 23, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, E-Mount: paso 23, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, E-Mount: paso 23, imagen 3 de 3
    • Remove mount plastic ring
    • remove mount spring ring
  24. Sony Alpha NEX-3N Lens Release Button Replacement, Sensor + Shutter: paso 24, imagen 1 de 1
    • Sensor + Shutter assembly comes off
  25. Sony Alpha NEX-3N Lens Release Button Replacement, Sensor Frame: paso 25, imagen 1 de 1
    • Separate sensor + shutter from another frame
  26. Sony Alpha NEX-3N Lens Release Button Replacement, The Sensor: paso 26, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, The Sensor: paso 26, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement, The Sensor: paso 26, imagen 3 de 3
    • Remove 3 ST1.7x5 screws
    • Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
  27. Sony Alpha NEX-3N Lens Release Button Replacement, Shutter: paso 27, imagen 1 de 2 Sony Alpha NEX-3N Lens Release Button Replacement, Shutter: paso 27, imagen 2 de 2
    • Remove sensor. the shutter assembly comes off.
    • Careful with 3 tiny spacers. Do NOT lose them.
  28. Sony Alpha NEX-3N Lens Release Button Replacement: paso 28, imagen 1 de 1
    • Separate Shutter assembly form the mount body.
  29. Sony Alpha NEX-3N Lens Release Button Replacement: paso 29, imagen 1 de 3 Sony Alpha NEX-3N Lens Release Button Replacement: paso 29, imagen 2 de 3 Sony Alpha NEX-3N Lens Release Button Replacement: paso 29, imagen 3 de 3
    • Remove 1 screw (from the "Front" side)
    • Separate shutter curtain (Photo 3) from charging motor (not shown).
  30. Sony Alpha NEX-3N Lens Release Button Replacement, Lens Release Button: paso 30, imagen 1 de 1
    • Yes, replacing this little innocent part needs 3+ hours!
  31. Sony Alpha NEX-3N Lens Release Button Replacement: paso 31, imagen 1 de 1
    • After removing the mount+shutter+sensor, it appears.
Conclusión
Terrance
Miembro Desde 11/17/09
6,368 Reputación
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 60
