Saltar al contenido principal
Skytex SP728 Screen Replacement
Qué necesitas
  1. Skytex SP728 Screen Replacement, Case: paso 1, imagen 1 de 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Screen Replacement: paso 2, imagen 1 de 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Screen Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Screen Replacement: paso 4, imagen 1 de 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Screen Replacement, Screen: paso 5, imagen 1 de 3 Skytex SP728 Screen Replacement, Screen: paso 5, imagen 2 de 3 Skytex SP728 Screen Replacement, Screen: paso 5, imagen 3 de 3
    • Follow the Case Replacement to separate the tablet from its backing
    • Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
    • Remove all tape connecting battery and circuit board to front case
    • Detach all connector strips from the circuit board
  6. Skytex SP728 Screen Replacement: paso 6, imagen 1 de 2 Skytex SP728 Screen Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, begin separating the front screen from the display
  7. Skytex SP728 Screen Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Once screen has been separated, use tweezers to remove front camera
Conclusión
To reassemble your device with a new screen, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 5-1, Brown Winter 2015 Miembro de USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 224
