Saltar al contenido principal
Skytex SP728 Case Replacement
Qué necesitas
  1. Skytex SP728 Case Replacement, Case: paso 1, imagen 1 de 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Case Replacement: paso 2, imagen 1 de 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Case Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Case Replacement: paso 4, imagen 1 de 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
Conclusión
To reassemble your device with a new case, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 5-1, Brown Winter 2015 Miembro de USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 129
