Saltar al contenido principal
Shark AI Ultra AV2511AE Drive Wheel Motor Replacement
Qué necesitas
  1. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement, Drive Wheel Motor: paso 1, imagen 1 de 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement, Drive Wheel Motor: paso 1, imagen 2 de 2
    • Put the device with the wheel side up.
    • Remove the five 11 mm screws surrounding the drive wheel using a Torx TR15 screwdriver.
    • Gently pull the wheel assembly out.
    • Make sure to pull lightly on the wheel assembly to ensure wires do not rip apart.
  2. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 2, imagen 1 de 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 2, imagen 2 de 2
    • Separate the wire connector from the wheel assembly using an opening tool.
  3. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 3, imagen 1 de 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 3, imagen 2 de 2
    • Remove the spring from the wheel assembly.
  4. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 4, imagen 1 de 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 4, imagen 2 de 2
    • Remove the four 7 mm screws around the gearbox using a Torx TR8 screwdriver.
    • Remove the gearbox cover.
    • Be careful about handling the wheel assembly with the gearbox exposed. Debris can enter in and the gears may fall out.
  5. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 5, imagen 1 de 3 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 5, imagen 2 de 3 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: paso 5, imagen 3 de 3
    • If holding the motor vertical, it may fall out once the screws are removed.
    • Using the Phillips #0 screwdriver, remove the two 4mm screws holding the motor to the gearbox.
    • Remove the motor.
Conclusión
Brycen Wirick
Miembro Desde 09/20/23
271 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 28
Todo El Tiempo: 250
