Saltar al contenido principal
Samsung Water Filter (Horizontal Filter) Replacement
Qué necesitas
  1. Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: paso 1, imagen 1 de 2 Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: paso 1, imagen 2 de 2
    • Open both French doors for the refrigerator compartment.
  2. Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: paso 2, imagen 1 de 2 Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: paso 2, imagen 2 de 2
    • Locate the water filter.
    • On this model, the filter can be found at the bottom of the main compartment, between the crisper drawers.
  3. Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: paso 3, imagen 1 de 2 Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: paso 3, imagen 2 de 2
    • Twist the water filter cap counter-clockwise until it's loosened from its housing.
  4. Samsung Water Filter (Horizontal Filter) Replacement: paso 4, imagen 1 de 2 Samsung Water Filter (Horizontal Filter) Replacement: paso 4, imagen 2 de 2
    • Pull the water filter straight out of its housing and remove it.
    • When you install the replacement filter, remember to remove the cap on the new filter.
  5. Samsung Water Filter (Horizontal Filter) Replacement: paso 5, imagen 1 de 2 Samsung Water Filter (Horizontal Filter) Replacement: paso 5, imagen 2 de 2
    • Run the water to flush the filter and check for leaks for a few minutes.
    • Press reset on the filter indicator.
Conclusión
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
Un comentario
IS there a difference from the HAF-QIN and the HAF-QIN/EXP
bigjon7379 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 26
Ultimos 30 días: 95
Todo El Tiempo: 14,797
