Saltar al contenido principal
Samsung SCV-VLUUST50 Flash Capacitor Replacement
Qué necesitas
  1. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: paso 1, imagen 1 de 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: paso 1, imagen 2 de 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: paso 1, imagen 3 de 3
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 2, imagen 1 de 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 2, imagen 2 de 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 2, imagen 3 de 3
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 3, imagen 1 de 1
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 4, imagen 1 de 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 4, imagen 2 de 2
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Flash Capacitor: paso 5, imagen 1 de 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Flash Capacitor: paso 5, imagen 2 de 2
    • Remove the screw securing the shutter button.
    • Lift the shutter button to remove it.
  6. Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 6, imagen 1 de 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 6, imagen 2 de 2
    • Remove the 3 visible screws with a Phillips #000 Driver
    • Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
  7. Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 7, imagen 1 de 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 7, imagen 2 de 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: paso 7, imagen 3 de 3
    • Pull the flash capacitor out of its compartment to expose the wires connected to it.
    • Cut the connecting wires with wire cutters.
    • Solder the wires to the new power source with a soldering iron and electrical solder.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 156
