Saltar al contenido principal
Samsung Refrigerator Fuse Block Replacement
Qué necesitas
  1. Samsung Refrigerator Fuse Block Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Fuse Block Replacement, Remove the board access panel: paso 2, imagen 1 de 1
    • Remove the screws securing the board access panel to the back of the refrigerator.
  3. Samsung Refrigerator Fuse Block Replacement: paso 3, imagen 1 de 2 Samsung Refrigerator Fuse Block Replacement: paso 3, imagen 2 de 2
    • Remove the board access panel.
  4. Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: paso 4, imagen 1 de 3 Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: paso 4, imagen 2 de 3 Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: paso 4, imagen 3 de 3
    • Squeeze the wide sides of the red connector to unlatch it from the fuse block.
    • Pull to disconnect the connector.
    • Repeat the procedure to disconnect the blue connector.
    • During reassembly, make sure the connectors lock in place. If they don't, you may need to flip their orientation.
  5. Samsung Refrigerator Fuse Block Replacement: paso 5, imagen 1 de 3 Samsung Refrigerator Fuse Block Replacement: paso 5, imagen 2 de 3 Samsung Refrigerator Fuse Block Replacement: paso 5, imagen 3 de 3
    • Use your fingers to pry and release the black plastic clip holding the left edge of the fuse block.
    • Lift out and remove the fuse block.
Conclusión
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 102
Todo El Tiempo: 368
