Saltar al contenido principal
Samsung Refrigerator Freezer Evaporator Components Replacement
Qué necesitas
  1. Samsung Refrigerator Freezer Evaporator Components Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Freezer Evaporator Components Replacement, Open the freezer drawer: paso 2, imagen 1 de 1
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer bins: paso 3, imagen 1 de 1
    • Lift and remove all the freezer bins from the drawer.
    • You should be left with a freezer door attached by two rails.
  4. Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer door: paso 4, imagen 1 de 3 Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer door: paso 4, imagen 2 de 3 Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer door: paso 4, imagen 3 de 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Freezer Evaporator Components Replacement: paso 5, imagen 1 de 2 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 5, imagen 2 de 2
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer compartment evaporator cover: paso 6, imagen 1 de 1
    • Remove the screws securing the freezer evaporator cover.
  7. Samsung Refrigerator Freezer Evaporator Components Replacement: paso 7, imagen 1 de 3 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 7, imagen 2 de 3 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 7, imagen 3 de 3
    • Don't try to fully remove the evaporator cover yet, as it's connected to the refrigerator by a few wires in the top right corner.
    • Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
    • Swing the evaporator cover upwards to access the connected wires behind it.
  8. Samsung Refrigerator Freezer Evaporator Components Replacement: paso 8, imagen 1 de 2 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 8, imagen 2 de 2
    • Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
  9. Samsung Refrigerator Freezer Evaporator Components Replacement: paso 9, imagen 1 de 1
    • Remove the evaporator cover.
  10. Samsung Refrigerator Freezer Evaporator Components Replacement, Disconnect the evaporator components: paso 10, imagen 1 de 2 Samsung Refrigerator Freezer Evaporator Components Replacement, Disconnect the evaporator components: paso 10, imagen 2 de 2
    • Remove the metal connector cover from the top right corner of the freezer back wall.
  11. Samsung Refrigerator Freezer Evaporator Components Replacement: paso 11, imagen 1 de 1
    • Use snips or scissors to cut any cable ties securing the wires.
  12. Samsung Refrigerator Freezer Evaporator Components Replacement: paso 12, imagen 1 de 2 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 12, imagen 2 de 2
    • Use your fingers to squeeze and disconnect the harness connector from the refrigerator.
  13. Samsung Refrigerator Freezer Evaporator Components Replacement: paso 13, imagen 1 de 3 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 13, imagen 2 de 3 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 13, imagen 3 de 3
    • Use your fingers to pry and remove the red and white connector retaining clips from the harness connector. This will separate the connector into three individual connectors.
    • The three connectors are stacked on top of each other. The order from top to bottom is:
    • Defrost coil thermal fuse (yellow connector with two red wires)
    • One end of the defrost coil (yellow connector with brown wire in the left pin)
    • Evaporator coil thermistor (white connector with two yellow wires)
  14. Samsung Refrigerator Freezer Evaporator Components Replacement: paso 14, imagen 1 de 3 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 14, imagen 2 de 3 Samsung Refrigerator Freezer Evaporator Components Replacement: paso 14, imagen 3 de 3
    • The freezer evaporator system includes these components:
    • Evaporator coil (filled with refrigerant and is non-removable)
    • Defrost coil
    • Evaporator coil thermister
    • Depending on your repair, remove and replace the affected components.
Conclusión
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 44
Todo El Tiempo: 280
