Saltar al contenido principal
Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement
Qué necesitas
  1. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Open the refrigerator doors: paso 2, imagen 1 de 2 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Open the refrigerator doors: paso 2, imagen 2 de 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the shelves: paso 3, imagen 1 de 2 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the shelves: paso 3, imagen 2 de 2
    • Remove all the loose shelves and bins from the refrigerator compartment.
    • The bottom shelf is clipped in place. Follow the next step to remove it.
  4. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 4, imagen 1 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 4, imagen 2 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 4, imagen 3 de 3
    • Two stiff plastic tabs (one on each side) secure the bottom shelf in place.
    • Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
    • If the shelf doesn't unclip, you can try using a flathead screwdriver to press each clip in.
    • Remove the bottom shelf.
  5. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: paso 5, imagen 1 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: paso 5, imagen 2 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: paso 5, imagen 3 de 3
    • Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
  6. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 6, imagen 1 de 1
    • Remove the screws securing the evaporator cover.
  7. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 7, imagen 1 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 7, imagen 2 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 7, imagen 3 de 3
    • Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
    • Don't try to fully remove the cover in this step, as it's connected by several wires.
  8. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 8, imagen 1 de 1
    • Squeeze and disconnect all the wire connectors connecting the evaporator cover to the refrigerator.
  9. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 9, imagen 1 de 2 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 9, imagen 2 de 2
    • Pull the evaporator cover towards you and remove it.
  10. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Disconnect the evaporator thermistor: paso 10, imagen 1 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Disconnect the evaporator thermistor: paso 10, imagen 2 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Disconnect the evaporator thermistor: paso 10, imagen 3 de 3
    • Use a flathead screwdriver to pry off and remove any connector retaining clips.
  11. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 11, imagen 1 de 2 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 11, imagen 2 de 2
    • Use your fingers to squeeze the thermistor's connector by the sides.
    • Pull the connector straight out to disconnect it.
  12. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: paso 12, imagen 1 de 1
    • Use snips or scissors to cut any cable ties securing the thermistor cable.
  13. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the evaporator thermistor: paso 13, imagen 1 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the evaporator thermistor: paso 13, imagen 2 de 3 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the evaporator thermistor: paso 13, imagen 3 de 3
    • Use your fingers to twist and unclip the thermistor from the evaporator coil.
    • Remove the evaporator thermistor.
Conclusión
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
465 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 199
