Saltar al contenido principal
Samsung Refrigerator Evaporator Drain Clip Replacement
Qué necesitas
  1. Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: paso 1, imagen 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: paso 1, imagen 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: paso 1, imagen 3 de 3
    • Using a spudger, pry off the cap covering the topmost screw.
  2. Samsung Refrigerator Evaporator Drain Clip Replacement: paso 2, imagen 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: paso 2, imagen 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: paso 2, imagen 3 de 3
    • Remove three 12.7 mm screws using a Phillips #0 screwdriver.
  3. Samsung Refrigerator Evaporator Drain Clip Replacement: paso 3, imagen 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: paso 3, imagen 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: paso 3, imagen 3 de 3
    • Use your hands or a spudger to pry back the plastic cover starting from the bottom.
    • Once all the clips are pulled out, loosen the cover by pushing it slightly up and out.
    • Do not pull the cover off yet; there are still connectors attaching the cover to the fridge.
  4. Samsung Refrigerator Evaporator Drain Clip Replacement: paso 4, imagen 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: paso 4, imagen 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: paso 4, imagen 3 de 3
    • Gently unplug both connectors.
    • Remember their orientations as it will be important during reassembly.
  5. Samsung Refrigerator Evaporator Drain Clip Replacement: paso 5, imagen 1 de 1
    • Using a hair dryer or heat gun, melt down any ice buildup in the draining well.
  6. Samsung Refrigerator Evaporator Drain Clip Replacement: paso 6, imagen 1 de 1
    • Cut out the old evaporating clip using a pair of cutting pliers.
  7. Samsung Refrigerator Evaporator Drain Clip Replacement: paso 7, imagen 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: paso 7, imagen 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: paso 7, imagen 3 de 3
    • Replace the old clip with a new evaporating clip.
Conclusión
7 personas más completaron esta guía.
Deep Patel
Miembro Desde 09/15/20
299 Reputación
1 Guía escrita
Equipo
3 comentarios
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
David Kahan - Contestar
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
nicO - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 82
Ultimos 30 días: 288
Todo El Tiempo: 13,603
