Saltar al contenido principal
Samsung Refrigerator Door Sensors Replacement
Qué necesitas
  1. Samsung Refrigerator Door Sensors Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Door Sensors Replacement, Remove the hinge cover: paso 2, imagen 1 de 1
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Door Sensors Replacement: paso 3, imagen 1 de 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Door Sensors Replacement: paso 4, imagen 1 de 2 Samsung Refrigerator Door Sensors Replacement: paso 4, imagen 2 de 2
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Door Sensors Replacement: paso 5, imagen 1 de 1
    • Remove the hinge cover.
  6. Samsung Refrigerator Door Sensors Replacement, Sensor information: paso 6, imagen 1 de 2 Samsung Refrigerator Door Sensors Replacement, Sensor information: paso 6, imagen 2 de 2
    • The door sensors are located in the hinge cover. In this example, the hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung Refrigerator Door Sensors Replacement, Remove the sensor: paso 7, imagen 1 de 2 Samsung Refrigerator Door Sensors Replacement, Remove the sensor: paso 7, imagen 2 de 2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung Refrigerator Door Sensors Replacement: paso 8, imagen 1 de 2 Samsung Refrigerator Door Sensors Replacement: paso 8, imagen 2 de 2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung Refrigerator Door Sensors Replacement: paso 9, imagen 1 de 1
    • Remove the door sensor.
Conclusión
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 61
Ultimos 30 días: 256
Todo El Tiempo: 1,003
