Saltar al contenido principal
Samsung Refrigerator Control Panel Replacement
Qué necesitas
  1. Samsung Refrigerator Control Panel Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: paso 2, imagen 1 de 2 Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: paso 2, imagen 2 de 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Control Panel Replacement, Loosen the control panel: paso 3, imagen 1 de 3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: paso 3, imagen 2 de 3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: paso 3, imagen 3 de 3
    • The control panel has plastic clips around its perimeter that secure it to the refrigerator wall.
    • Insert a spudger into the seam along the right edge of the control panel.
    • You can also use a flathead screwdriver, but be careful not to let the screwdriver slip, or you'll scratch your refrigerator surface.
    • Press the spudger in firmly and pry to loosen the panel.
    • Use your spudger to slide and pry around the control panel to loosen it from the refrigerator wall.
  4. Samsung Refrigerator Control Panel Replacement: paso 4, imagen 1 de 1
    • Flip the control panel over to reveal the cable connector.
  5. Samsung Refrigerator Control Panel Replacement: paso 5, imagen 1 de 2 Samsung Refrigerator Control Panel Replacement: paso 5, imagen 2 de 2
    • Use your fingers to slide the cable connector out of its socket.
  6. Samsung Refrigerator Control Panel Replacement, Remove the control panel: paso 6, imagen 1 de 1
    • Remove the control panel.
Conclusión
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 96
Todo El Tiempo: 486
