Saltar al contenido principal
Samsung RF28R7201SG Refrigerator Door Sensors Replacement
Qué necesitas
  1. Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Remove the hinge cover: paso 2, imagen 1 de 1
    • Use a Phillips screwdriver to remove the three 18.5 mm-long screws securing the hinge cover on the top of the refrigerator.
  3. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: paso 3, imagen 1 de 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: paso 4, imagen 1 de 2 Samsung RF28R7201SG Refrigerator Door Sensors Replacement: paso 4, imagen 2 de 2
    • Use your fingers to squeeze and disconnect the blue wire connector.
    • Use your fingers to squeeze and disconnect the white wire connector.
  5. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: paso 5, imagen 1 de 1
    • Remove the hinge cover.
  6. Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Sensor information: paso 6, imagen 1 de 2 Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Sensor information: paso 6, imagen 2 de 2
    • The hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Remove the sensor: paso 7, imagen 1 de 2 Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Remove the sensor: paso 7, imagen 2 de 2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: paso 8, imagen 1 de 2 Samsung RF28R7201SG Refrigerator Door Sensors Replacement: paso 8, imagen 2 de 2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: paso 9, imagen 1 de 1
    • Remove the door sensor.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,927 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
34 Miembros
596 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 184
