Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Screen replacement may need to be done when the screen is damaged, such as lines on the screen and not showing anything. Refer to the Troubleshooting page to see more information about this. This guide will display the steps needed to replace a damaged screen on Samsung RC512.
  1. Place the laptop upside down.
    • Place the laptop upside down.
  2. Locate two notches above the battery. Slide both battery locking notches to either side to remove the battery.
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. The Laptop should be off before removing the battery. Slide both battery locking notches to either side to remove the battery. Pull the battery out.
    • The Laptop should be off before removing the battery.
  4. Remove the gray covers with tweezers to expose the 4mm screws. Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws. Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
  5. Insert the blue plastic opening tool into the bezel and rear housing of the screen. Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
  6. With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop. As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
  7. Gently lay the LCD onto the keyboard. Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together. Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
Conclusión
Una persona más ha completado esta guía.
Juri Ando
Miembro Desde 15/09/16
896 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 18-2, Blackwell Fall 2016 Miembro de USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 516
