Saltar al contenido principal
Samsung NP900X4B Battery Replacement
Qué necesitas
  1. Samsung NP900X4B Battery Replacement, Battery: paso 1, imagen 1 de 2 Samsung NP900X4B Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung NP900X4B Battery Replacement: paso 2, imagen 1 de 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung NP900X4B Battery Replacement: paso 3, imagen 1 de 2 Samsung NP900X4B Battery Replacement: paso 3, imagen 2 de 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung NP900X4B Battery Replacement: paso 4, imagen 1 de 1
    • Lift and pull out the battery.
Conclusión
Nathan LeBlanc
Miembro Desde 10/17/18
109 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 598
