Saltar al contenido principal
Samsung NP350E5C-A02US Wifi card Replacement
Qué necesitas
  1. Samsung NP350E5C-A02US Wifi card Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Wifi card Replacement: paso 2, imagen 1 de 1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Wifi card Replacement: paso 3, imagen 1 de 1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Wifi card Replacement, Wifi card: paso 4, imagen 1 de 1
    • Look for the compartment with the Wifi symbol on it.
  5. Samsung NP350E5C-A02US Wifi card Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the 5 mm screw located beside the Wifi symbol.
  6. Samsung NP350E5C-A02US Wifi card Replacement: paso 6, imagen 1 de 1
    • Gently pry up cover using a plastic spudger or opening tool.
  7. Samsung NP350E5C-A02US Wifi card Replacement: paso 7, imagen 1 de 1
    • Gently remove the two wires attached to the Wifi card by using a plastic opening tool or plastic spudger to pry up from under where the wire is attached.
  8. Samsung NP350E5C-A02US Wifi card Replacement: paso 8, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the M2.5x3 mm screw holding in the Wifi card.
  9. Samsung NP350E5C-A02US Wifi card Replacement: paso 9, imagen 1 de 1
    • Gently pull out the Wifi card.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 280
