Saltar al contenido principal
Samsung NP N310 HAA2US Back Panel Replacement
Qué necesitas
  1. Samsung NP N310 HAA2US Back Panel Replacement, Battery: paso 1, imagen 1 de 3 Samsung NP N310 HAA2US Back Panel Replacement, Battery: paso 1, imagen 2 de 3 Samsung NP N310 HAA2US Back Panel Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US Back Panel Replacement, Back Panel: paso 2, imagen 1 de 2 Samsung NP N310 HAA2US Back Panel Replacement, Back Panel: paso 2, imagen 2 de 2
    • Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
    • If there are rubber pads covering the screws, use a spudger to remove the rubber pads.
  3. Samsung NP N310 HAA2US Back Panel Replacement: paso 3, imagen 1 de 3 Samsung NP N310 HAA2US Back Panel Replacement: paso 3, imagen 2 de 3 Samsung NP N310 HAA2US Back Panel Replacement: paso 3, imagen 3 de 3
    • Insert the plastic opening tool in the break between the back panel, and the keyboard.
    • Drag the opening tool around the edge to separate it.
    • Pull the back panel off of the laptop.
Conclusión
Amir Afridi
Miembro Desde 09/29/16
626 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 4-1, Passmore Fall 2016 Miembro de USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
Miembros de 4
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 403
