Saltar al contenido principal
Samsung LNT4669FX-XAA TV Power Supply Board Replacement
Qué necesitas
    • Be sure to unplug the TV from the main wall outlet.
    • Carefully lay the TV screen down on a clean flat table with the back side facing you.
    • Using a #3 Phillips head screwdriver, remove the screws holding the back cover on.
    • Thoroughly clean the cover and boards using a damp towel (I like to use 91% isopropyl alcohol) and if heavily soiled use a vacuum with a brush.
    • Using the #3 Phillips head screwdriver, remove the screws holding the power supply board on.
    • Unplug the connectors connected to the board setting aside and carefully noting placement for later connection to the new board.
    • Insert the new power supply board into the location where the old board was located.
    • Follow the previous steps to connect the cables and screw in the screws.
    • Follow the first step in reverse to install the back cover.
    • Plug the power cord into a wall outlet and power on the TV to verify performance.
Conclusión
You can also repair your Power Supply Board potentially by using the BN44-00166C repair kit.
See the Attached Documents schematic for further Power Supply Board details.
2 personas más completaron esta guía.
Documentos Adjuntos
James Finch
Miembro Desde 10/14/17
2,366 Reputación
13 Guías creadas
2 comentarios
should we use the same power supply brand/type?
A Shahyadi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 73
Todo El Tiempo: 10,791
