Saltar al contenido principal
Samsung Galaxy Tab 3 Kids Battery Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before beginning this repair, make sure that the device is completely turned off.
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids  Battery Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: paso 2, imagen 2 de 2
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids  Battery Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: paso 3, imagen 2 de 2
    • Remove the four 1.2 mm Phillips #000 screws surrounding the battery.
  4. Samsung Galaxy Tab 3 Kids  Battery Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: paso 4, imagen 2 de 2
    • Use your hands to gently lift the battery up to remove it.
    • If it does not come off easily, there may be some glue underneath the battery and may need to be pried off with a spudger.
Conclusión
4 personas más completaron esta guía.
ajhoffman
Miembro Desde 01/04/14
182 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 2-6, Nance Fall 2016 Miembro de USF Tampa, Team 2-6, Nance Fall 2016
USFT-NANCE-F16S2G6
4 Miembros
10 Guías creadas
2 comentarios
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
khaledm2012 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 2,028
