Saltar al contenido principal
Samsung Galaxy Tab 3 10.1 Rear Case Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 10.1 Rear Case Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Rear Case Replacement, Rear Case: paso 1, imagen 2 de 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Rear Case Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Rear Case Replacement: paso 2, imagen 2 de 2
    • Lift the case up to remove it.
Conclusión
2 personas más completaron esta guía.
Corey Brown
Miembro Desde 06/24/16
8,832 Reputación
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 1,904
