Saltar al contenido principal
Samsung Galaxy Tab 3 10.1 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: paso 1, imagen 2 de 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 2, imagen 2 de 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: paso 3, imagen 1 de 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: paso 3, imagen 2 de 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: paso 3, imagen 3 de 3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 4, imagen 2 de 2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 7, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 7, imagen 2 de 2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 8, imagen 2 de 2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: paso 9, imagen 2 de 2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 10, imagen 1 de 1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 11, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 12, imagen 1 de 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 12, imagen 2 de 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 12, imagen 3 de 3
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  13. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 13, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: paso 13, imagen 2 de 2
    • Use nylon-tipped tweezers to remove the motherboard.
Conclusión
12 personas más completaron esta guía.
Corey Brown
Miembro Desde 06/24/16
8,682 Reputación
11 Guías creadas
3 comentarios
Great guide, project completed.
Edgar Merced - Contestar
Simplemente GENIAL!!!!
Muy claro.
Felicitaciones.
Cuenten con mis aportes al foro
Ahora que pude retirar placa base voy a ver esquemático, porque WIFI se desactiva . No funciona.
Saludos
DARIO GASTAUDO - Contestar
very easy to destroy the Galaxy. finicky to the max!
ein Stein - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 45
Todo El Tiempo: 9,618
