Saltar al contenido principal
Samsung Galaxy Tab 3 10.1 LED Light Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: paso 1, imagen 2 de 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 LED Light Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 LED Light Replacement: paso 2, imagen 2 de 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: paso 3, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: paso 3, imagen 2 de 2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  4. Samsung Galaxy Tab 3 10.1 LED Light Replacement: paso 4, imagen 1 de 1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  5. Samsung Galaxy Tab 3 10.1 LED Light Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab 3 10.1 LED Light Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab 3 10.1 LED Light Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the flat end of the spudger to flip up the press-fit connector attaching the LED to the motherboard.
    • Remove the LED indicator light by gently pulling upward with nylon-tipped tweezers.
Conclusión
4 personas más completaron esta guía.
Corey Brown
Miembro Desde 06/24/16
8,688 Reputación
11 Guías creadas
Un comentario
Above article is useful for removing LED Light.
Which LED are we removing - Camera Flash or screen display LED?
How to fit new LED Light?
Please reply. I am facing issues with screen display and flash for camera is also not working
Ashwini Dughad - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 35
Todo El Tiempo: 4,213
