Saltar al contenido principal
Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: paso 1, imagen 2 de 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: paso 2, imagen 2 de 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Front-Facing Camera: paso 3, imagen 1 de 1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  4. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
    • Remove the camera by gently pulling upward with a pair of tweezers.
Conclusión
2 personas más completaron esta guía.
Corey Brown
Miembro Desde 06/24/16
8,826 Reputación
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 876
