Introducción
The Samsung Galaxy S9 only has one rear facing camera. You would need to change the camera if the lens became cracked or scratched. Be sure to be level and straight when putting on the replacement camera.
Be forewarned- replacing the rear facing camera will impair your phone's waterproof capabilities unless you also replace the adhesive seal on the back cover.
Qué necesitas
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
6 personas más completaron esta guía.
