Introducción
If your main camera glass is broken, you can either remove and replace the lens glass, or replace the whole lens assembly.
Removing the lens while the phone is still assembled may cause small pieces of glass to fall into the camera, but is a faster fix that requires less disassembly.
The lens assembly replacement is longer, and requires removing the back panel, but it is less likely to damage the camera itself. This procedure includes replacing the glass lens and the camera bezel, and will require replacement rear glass adhesive.
Qué necesitas
Follow this procedure if you are replacing only the glass lens over the rear-facing camera.
Follow this longer procedure to replace the bezel and camera lens, which are installed on the rear case.
33 personas más completaron esta guía.
12 comentarios
THANK YOU SO MUCH for the first video!!!
Follow up... What happens if there is a bit of dust? Is there a way to get rid of it?
I ordered 2 lens replacements and neither one of the lenses have adhesive on either side do I need to buy some kind of adhesive sepratly or should 1 or these sides already have it on there
same thing with mine josh albano i just plopped it in and am going to hope for the best.
How can I make sure I don't get my replacement glass in backward.....because my focus is still gone. I'm devastated because I purchased this phone specifically for the camera to take pictures to upload to my eBay account. I worked for almost a full year before I could afford to buy this camera phone and I purchased it outright from straight talk. I own my camera and it is not insured. I followed your directions to replace my lens and now I'm worried I might have it in backward. How can I tell if the lens is in place incorrectly? By the way, my phone has never been dropped. It has been protected by an otter box since its purchase. My lens seemingly self-imploded. Just the strangest thing. Other than the lens, my camera doesn't have a scratch on it! Thank you for any help. Molly
