Introducción
This motherboard replacement guide applies to the Verizon Samsung Galaxy S4 Mini, model number SCH-I435.
Qué necesitas
Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
3 personas más completaron esta guía.
