Saltar al contenido principal
Samsung Galaxy S4 Active Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: paso 1, imagen 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Motherboard Replacement, MicroSD Card: paso 2, imagen 1 de 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Motherboard Replacement, Battery: paso 3, imagen 1 de 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Motherboard Replacement, SIM Card: paso 4, imagen 1 de 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Motherboard Replacement, Midframe: paso 5, imagen 1 de 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Motherboard Replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: paso 7, imagen 1 de 3 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: paso 7, imagen 2 de 3 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: paso 7, imagen 3 de 3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard.
Conclusión
22 personas más completaron esta guía.
Geoff Wacker
Miembro Desde 09/30/13
90,038 Reputación
89 Guías creadas
4 comentarios
I need a diagnosis. My device seems to be in a boot loop....any thought and suggestions would be helpful.
Justin Lujan - Contestar
Nota1000 fera + parabéns
ricflavianoop - Contestar
After the replacement of the motherboard, is there a procedure to Programm the old IMEI or will it imply a new IMEI?
Markus Elgrande - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 9,321
