Saltar al contenido principal
Samsung Galaxy S4 Active MicroSD Card Replacement
Qué necesitas
  1. Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: paso 1, imagen 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active MicroSD Card Replacement, MicroSD Card: paso 2, imagen 1 de 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
Conclusión
3 personas más completaron esta guía.
Geoff Wacker
Miembro Desde 09/30/13
89,953 Reputación
89 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,474
