Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy S10+ SIM/MicroSD Card Replacement
Qué necesitas
  1. Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: paso 1, imagen 1 de 3 Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: paso 1, imagen 2 de 3 Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: paso 1, imagen 3 de 3
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
Conclusión
After you've completed the repair, follow this guide to test your repair.
6 personas más completaron esta guía.
Arthur Shi
Miembro Desde 01/03/18
326,658 Reputación
810 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 124
24,373 Guías creadas
6Guía Comentarios
I have the same question. I'm sure you've taken enough of these apart for repair. (Galaxy s10's and pluses) Can you guys see what's at the end of the hole? Any research that I've found says that the hole is straight and comes to an end and the microphone is 90° to that, so it cannot be poked by the pin, is this true? (I hope it is, and to give us peace of mind!) I don't want to have to take apart my phone. I'm sure there are lots people out here that have poked this %#*@ hole and are freaking that we have wrecked a $1600.00 phone! And then, if you could kindly please then post an answer plainly in the instructions for the SIM installation somewhere in the body of this installation article. I have seen no definitive answer to this mistake in any other article that I've read. Ifixit is the premiere repair company for phones, this should be solved here. Thanks in advance I hope. I've used your services multiple times in the past for various breakages of our family phones in Chicago, you've always been great.
Lin Car - Contestar Compartir
Hi Lin,
Please look for the answer in step 1’s comments.
Arthur Shi - Compartir
I inserted the pin in the microphone hole first. Thank you for setting my mind at ease that I didn’t damage anything,
Craig Thielke - Contestar Compartir
Where can you order a OEM SM-G975U Prism Blue sim card tray from? I want a genuine Samsung replacement.
MarkC 609 - Contestar Compartir
well we have a dilemma here my s10+ ihas got a micro sim card stuck in the sd slot see if you can get it out by taking the phone apartand also ill need directions to you
Kevin Gaiser - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 33
Ultimos 30 días: 122
Todo El Tiempo: 17,762
