Saltar al contenido principal
Samsung Galaxy S Vibrant Battery Replacement
Qué necesitas
  1. Samsung Galaxy S Vibrant Battery Replacement, Battery: paso 1, imagen 1 de 3 Samsung Galaxy S Vibrant Battery Replacement, Battery: paso 1, imagen 2 de 3 Samsung Galaxy S Vibrant Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Battery Replacement: paso 2, imagen 1 de 2 Samsung Galaxy S Vibrant Battery Replacement: paso 2, imagen 2 de 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
Conclusión
Equipo
Cal Poly, Team 18-37, Regan Winter 2013 Miembro de Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 1,636
