Saltar al contenido principal
Samsung Galaxy J3 Eclipse Home Button Replacement
Qué necesitas
  1. Samsung Galaxy J3 Eclipse Home Button Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
    • Do not apply heat to any one edge of the phone for longer than a few seconds. Instead, use a continuous motion around the phone's edges.
  2. Samsung Galaxy J3 Eclipse Home Button Replacement: paso 2, imagen 1 de 2 Samsung Galaxy J3 Eclipse Home Button Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
    • Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
    • When using the pry tool, do not use too much force or the phone's internals could be damaged.
    • Do not insert your tool more than 1cm into the top edge of the phone to avoid damaging the fragile cables.
  3. Samsung Galaxy J3 Eclipse Home Button Replacement: paso 3, imagen 1 de 3 Samsung Galaxy J3 Eclipse Home Button Replacement: paso 3, imagen 2 de 3 Samsung Galaxy J3 Eclipse Home Button Replacement: paso 3, imagen 3 de 3
    • Gently lift lower side and loosen all edges to hinge screen up from bottom.
    • Do not try to completely remove the display from the frame yet. Simply try to loosen up all the edges.
  4. Samsung Galaxy J3 Eclipse Home Button Replacement: paso 4, imagen 1 de 3 Samsung Galaxy J3 Eclipse Home Button Replacement: paso 4, imagen 2 de 3 Samsung Galaxy J3 Eclipse Home Button Replacement: paso 4, imagen 3 de 3
    • Use your prying tool to slowly pry up on the bottom right corner of the white cable guard, exposing a thin ribbon cable connector.
  5. Samsung Galaxy J3 Eclipse Home Button Replacement: paso 5, imagen 1 de 3 Samsung Galaxy J3 Eclipse Home Button Replacement: paso 5, imagen 2 de 3 Samsung Galaxy J3 Eclipse Home Button Replacement: paso 5, imagen 3 de 3
    • Pry up the ribbon cable connector revealed from under the cable guard and remove the display from the device.
    • Clean the residue from the phone edges before re-assembling phone with new screen.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 328
