Qué necesitas
At the top of the device there is a small notch that is used to remove the battery door.
Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side.
Using a pry tool or your fingernail, pry the battery up towards you.
You have now removed the battery!
Remove the 6 Phillips head screws that hold the rear housing in place.
Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
Using a spudger/plastic pry tool lift the brown ZIF tab on the front-facing camera connector.
3 personas más completaron esta guía.
