Saltar al contenido principal
Samsung Galaxy Attain 4G Battery Replacement
Qué necesitas
  1. Samsung Galaxy Attain 4G Battery Replacement, Placement: paso 1, imagen 1 de 1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Battery Replacement, Battery Door Removal: paso 2, imagen 1 de 2 Samsung Galaxy Attain 4G Battery Replacement, Battery Door Removal: paso 2, imagen 2 de 2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: paso 3, imagen 1 de 3 Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: paso 3, imagen 2 de 3 Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: paso 3, imagen 3 de 3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Battery Replacement, Heads Up!: paso 4, imagen 1 de 1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
Conclusión
Una persona más ha completado esta guía.
Josh Forester
Miembro Desde 11/28/10
2,497 Reputación
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 387
