Saltar al contenido principal
Samsung Galaxy A3 Display / LCD Replacement
Qué necesitas
  1. Samsung Galaxy A3 Display / LCD Replacement, Display / LCD: paso 1, imagen 1 de 1
    • Heat up the edges of the display with a heat gun or iPad opener.
  2. Samsung Galaxy A3 Display / LCD Replacement: paso 2, imagen 1 de 2 Samsung Galaxy A3 Display / LCD Replacement: paso 2, imagen 2 de 2
    • Using a pick or slim plastic tool, work around the edge of the frame to loosen the glass.
    • Watch out for the ear speaker, camera and light sensor on the top of the phone.
    • When working the glass free around the bottom of the phone, slide the tool out to avoid damaging the left and right home buttons (as shown in picture 2).
    • NOTE: The LCD is also glued to the frame and will most likely break when removing the display.
  3. Samsung Galaxy A3 Display / LCD Replacement: paso 3, imagen 1 de 2 Samsung Galaxy A3 Display / LCD Replacement: paso 3, imagen 2 de 2
    • Once the display has been disconnected, lift the top of the display away from the phone to expose the home buttons (Shown in green)
    • Pry the contacts gently off the underside of the glass and push them back into the recesses on the phone (shown in yellow).
  4. Samsung Galaxy A3 Display / LCD Replacement: paso 4, imagen 1 de 1
    • Connect the new display and seat it in the phone, without removing the plastic for the adhesive.
    • Turn the phone on to make sure the display and home buttons work. If you glue the display without testing it first, it's a pain to take it off again once it has been glued and runs the risk of the display breaking.
    • If the display works, remove the plastic covering the adhesive and seat the display in the phone. Push gently around the edges to ensure a good seal
Conclusión
To reassemble your device, follow these instructions in reverse order. Do not attempt this while driving or lovemaking :)
41 personas más completaron esta guía.
Harvey
Miembro Desde 02/15/16
5,235 Reputación
10 Guías creadas
6 comentarios
The lcd on my phone was physically glued to the inside of the phone so it broke when trying to remove it (which wasn't a problem as it was dead anyway) but this needs to be mentioned as it isn't!
Clems - Contestar
It’s been mentioned in step 2
Siamak -
nice man really cool staff
Shelton Chiuswa - Contestar
Is the concept the same with newer models of the Samsung Galaxy A3?
Frederik Novak Jansen - Contestar
The 2016 Model is different, so I would look for the model specific repair information:
Samsung A3 2016 Model - A310F Display / LCD Replacement
This is a guide I wrote for the 2016 model...Hope it helps!
Harvey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 46
Todo El Tiempo: 46,218
