Qué necesitas
Use a heat gun or iOpener to heat the back of the phone.
Insert a spudger or thin bladed tool between the batery cover and frame.
Slide all the way around to release the adhesive holding the cover.
The battery cover is also glass and can break if too much pressure is applied when removeing.
Using a heatgun, heat the front of the display.
Use a spudger or pick to work the display and LCD free from the plastic housing. NOTE: The LCD is also glued to the frame and will probably break as well.
When mounting the new display, the display cable slots through a gap in the plastic frame and attaches to the mainboard.
Reattach the daughter board connector to the mainboard.
When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery.
Re-connect the display connector, camera and cable to the mainboard.
Screw the mainboard to the frame
5 personas más completaron esta guía.
