Saltar al contenido principal
Samsung Chromebook Series 3 Battery Replacement
Qué necesitas
  1. Samsung Chromebook Series 3 Battery Replacement, Bottom Cover: paso 1, imagen 1 de 3 Samsung Chromebook Series 3 Battery Replacement, Bottom Cover: paso 1, imagen 2 de 3 Samsung Chromebook Series 3 Battery Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Battery Replacement: paso 2, imagen 1 de 3 Samsung Chromebook Series 3 Battery Replacement: paso 2, imagen 2 de 3 Samsung Chromebook Series 3 Battery Replacement: paso 2, imagen 3 de 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Battery Replacement: paso 3, imagen 1 de 3 Samsung Chromebook Series 3 Battery Replacement: paso 3, imagen 2 de 3 Samsung Chromebook Series 3 Battery Replacement: paso 3, imagen 3 de 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Battery Replacement: paso 4, imagen 1 de 3 Samsung Chromebook Series 3 Battery Replacement: paso 4, imagen 2 de 3 Samsung Chromebook Series 3 Battery Replacement: paso 4, imagen 3 de 3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Battery Replacement, Battery: paso 5, imagen 1 de 3 Samsung Chromebook Series 3 Battery Replacement, Battery: paso 5, imagen 2 de 3 Samsung Chromebook Series 3 Battery Replacement, Battery: paso 5, imagen 3 de 3
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Battery Replacement: paso 6, imagen 1 de 3 Samsung Chromebook Series 3 Battery Replacement: paso 6, imagen 2 de 3 Samsung Chromebook Series 3 Battery Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Battery Replacement: paso 7, imagen 1 de 2 Samsung Chromebook Series 3 Battery Replacement: paso 7, imagen 2 de 2
    • You can now remove the battery.
Conclusión
25 personas más completaron esta guía.
Andrey Radchishin
Miembro Desde 01/21/15
1,833 Reputación
4 Guías creadas
Equipo
UWT Liner: Group 1 Miembro de UWT Liner: Group 1
Community
5 Miembros
8 Guías creadas
7 comentarios
I have replaced my battery 2x and I can not charge them. They work when I get them and they keep the charge while it’s plugged in, but will not increase the charge . Any ideas what I can do?
nier101 - Contestar
It could be the AC power adapter is not functioning correctly. You may want to double check the charging port, too. (Samsung Chromebook Series 3 Charging Port Replacement)
Jorge Gomes -
I had a similar problem and it turned out I had not properly attached the battery connector -- the instruction is a little misleading. You do have to get those pins into the connector, which requires some horizontal movement. Here's a cute trick: plug in the AC adapter before you plug in the battery (and with the back still off -- plug in the AC directly, not through the hole in the case.) Because the battery is not connected, you'll see the green light. When you've made the connection, charging will begin and the light will change to yellow. So just fiddle -- gently -- with the battery connector until you see that yellow.
Clifford Story -
As an aside… When removing the back, the little spring-loaded “door” came loose and fell out before I was able to see how it was attached. I figured it out, but would love to have additional instructions for items such as this. I didn’t find a teardown for this model, but will keep looking.
Thanks for this contribution.
Joan Clark - Contestar
The entire process was much simpler than I had imagined it would be. I was a little concerned about applying a lot of pressure to remove some of the screws. Otherwise, it came apart like the back of a cell phone, and pushed back together just as easily. Anyone know of a worth while battery recycling center?
Laro Nicol - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 27
Ultimos 30 días: 114
Todo El Tiempo: 10,947
