Saltar al contenido principal
Samsung Chromebook Series 3 Charging Port Replacement
Qué necesitas
  1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: paso 1, imagen 1 de 3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: paso 1, imagen 2 de 3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Charging Port Replacement: paso 2, imagen 1 de 3 Samsung Chromebook Series 3 Charging Port Replacement: paso 2, imagen 2 de 3 Samsung Chromebook Series 3 Charging Port Replacement: paso 2, imagen 3 de 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Charging Port Replacement: paso 3, imagen 1 de 3 Samsung Chromebook Series 3 Charging Port Replacement: paso 3, imagen 2 de 3 Samsung Chromebook Series 3 Charging Port Replacement: paso 3, imagen 3 de 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Charging Port Replacement: paso 4, imagen 1 de 3 Samsung Chromebook Series 3 Charging Port Replacement: paso 4, imagen 2 de 3 Samsung Chromebook Series 3 Charging Port Replacement: paso 4, imagen 3 de 3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: paso 5, imagen 1 de 3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: paso 5, imagen 2 de 3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: paso 5, imagen 3 de 3
    • Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
  6. Samsung Chromebook Series 3 Charging Port Replacement: paso 6, imagen 1 de 2 Samsung Chromebook Series 3 Charging Port Replacement: paso 6, imagen 2 de 2
    • Remove the metal cover above the charging port module by pulling up and moving it slightly left.
  7. Samsung Chromebook Series 3 Charging Port Replacement: paso 7, imagen 1 de 3 Samsung Chromebook Series 3 Charging Port Replacement: paso 7, imagen 2 de 3 Samsung Chromebook Series 3 Charging Port Replacement: paso 7, imagen 3 de 3
    • Pull out the charging port module connector by pulling directly up on it.
    • When reassembling, reconnect by positioning the connector directly above its original position and pushing down.
  8. Samsung Chromebook Series 3 Charging Port Replacement: paso 8, imagen 1 de 2 Samsung Chromebook Series 3 Charging Port Replacement: paso 8, imagen 2 de 2
    • You can now pull out the charging port module.
Conclusión
10 personas más completaron esta guía.
Andrey Radchishin
Miembro Desde 01/21/15
1,860 Reputación
4 Guías creadas
Equipo
UWT Liner: Group 1 Miembro de UWT Liner: Group 1
Community
5 Miembros
8 Guías creadas
2 comentarios
What is the reference number for this charging port?
How to find it on ebay/other?
rafal - Contestar
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
Andrey Radchishin -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 40
Todo El Tiempo: 17,552
