Saltar al contenido principal
Samsung 500C ChromeBook Battery Replacement
Qué necesitas
  1. Samsung 500C ChromeBook Battery Replacement, Battery: paso 1, imagen 1 de 2 Samsung 500C ChromeBook Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: paso 2, imagen 1 de 3 Samsung 500C ChromeBook Battery Replacement: paso 2, imagen 2 de 3 Samsung 500C ChromeBook Battery Replacement: paso 2, imagen 3 de 3
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
Conclusión
3 personas más completaron esta guía.
Equipo
Michigan Tech, Team 1-2, Lauer Spring 2014 Miembro de Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 Miembros
10 Guías creadas
3 comentarios
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Contestar
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 23
Todo El Tiempo: 3,210
