Saltar al contenido principal
SVP 5800 Front Casing Replacement
Qué necesitas
  1. SVP 5800 Front Casing Replacement, Strap Hook: paso 1, imagen 1 de 3 SVP 5800 Front Casing Replacement, Strap Hook: paso 1, imagen 2 de 3 SVP 5800 Front Casing Replacement, Strap Hook: paso 1, imagen 3 de 3
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. SVP 5800 Front Casing Replacement, Front Casing: paso 2, imagen 1 de 2 SVP 5800 Front Casing Replacement, Front Casing: paso 2, imagen 2 de 2
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. SVP 5800 Front Casing Replacement: paso 3, imagen 1 de 2 SVP 5800 Front Casing Replacement: paso 3, imagen 2 de 2
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  4. SVP 5800 Front Casing Replacement: paso 4, imagen 1 de 2 SVP 5800 Front Casing Replacement: paso 4, imagen 2 de 2
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
Conclusión
Una persona más ha completado esta guía.
Equipo
Marist, Team 1-3, Laflen Spring 2016 Miembro de Marist, Team 1-3, Laflen Spring 2016
MARS-LAFLEN-S16S1G3
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 279
