Introducción
This guides enumerates the steps of removing and replacing the front casing of the SPV Aqua 5800 Camera in order to protect the mechanisms within.
Qué necesitas
Locate the two 3.5 mm screws on the side of the device.
Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
Una persona más ha completado esta guía.
