Introducción
How to replace the back casing to SVP Aqua 5800
Qué necesitas
Locate the two 3.5 mm screws on the side of the device.
Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
Insert the flat end of wide metal spudger into the seam of the plastic buffer surrounding the buttons and pry it open.
Locate the 2 mm screw that is next to the battery compartment.
Using the PH J000 phillips head screwdriver, apply pressure to the screw head and turn in a counter clockwise motion until the screw is loose.
Una persona más ha completado esta guía.
