Saltar al contenido principal
Ryobi P235 Battery Replacement
  1. Ryobi P235 Battery Replacement, Battery: paso 1, imagen 1 de 2 Ryobi P235 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Battery Replacement: paso 2, imagen 1 de 2 Ryobi P235 Battery Replacement: paso 2, imagen 2 de 2
    • Pull the battery away from the drill housing while holding in both tabs.
Conclusión
3 personas más completaron esta guía.
Paul Sousa
Miembro Desde 10/29/19
805 Reputación
5 Guías creadas
Equipo
Un comentario
Replacement Power Tool Battery for Ryobi P235
Type: Li-ion
Volt: 18V
Capacity: 2500mAh
Color: Black
Weight: 210g
Dimension: 135.70 x 76.00 x 98.30mm
View more about this battery on http://www.drillbattery.co.uk/batterysal...
Drillbatterycomau - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 540
