Saltar al contenido principal
Ryobi P202 Level Gauge Replacement
Qué necesitas
  1. Ryobi P202 Level Gauge Replacement, Battery: paso 1, imagen 1 de 3 Ryobi P202 Level Gauge Replacement, Battery: paso 1, imagen 2 de 3 Ryobi P202 Level Gauge Replacement, Battery: paso 1, imagen 3 de 3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Level Gauge Replacement, Right Side Case: paso 2, imagen 1 de 2 Ryobi P202 Level Gauge Replacement, Right Side Case: paso 2, imagen 2 de 2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Level Gauge Replacement: paso 3, imagen 1 de 2 Ryobi P202 Level Gauge Replacement: paso 3, imagen 2 de 2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Level Gauge Replacement, Level Gauge: paso 4, imagen 1 de 3 Ryobi P202 Level Gauge Replacement, Level Gauge: paso 4, imagen 2 de 3 Ryobi P202 Level Gauge Replacement, Level Gauge: paso 4, imagen 3 de 3
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
Conclusión
Joseph Eckstein
Miembro Desde 04/07/15
1,596 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 17-6, Forte Spring 2015 Miembro de Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 446
