Saltar al contenido principal
Ryobi CSB135L Power Cord Replacement
Qué necesitas
  1. Ryobi CSB135L Power Cord Replacement, Power Cord: paso 1, imagen 1 de 1
    • Place the saw on a flat surface.
    • Make sure the saw is unplugged and unpowered.
  2. Ryobi CSB135L Power Cord Replacement: paso 2, imagen 1 de 2 Ryobi CSB135L Power Cord Replacement: paso 2, imagen 2 de 2
    • Remove the six M4x16mm Phillips screws and the two M4.5x35mm screws using a Phillips #2 screwdriver.
    • Remove the front facing half of the handle assembly exposing the internals of the saw.
  3. Ryobi CSB135L Power Cord Replacement: paso 3, imagen 1 de 2 Ryobi CSB135L Power Cord Replacement: paso 3, imagen 2 de 2
    • After removing the handle assembly locate the trigger switch and wire nut in the saw.
    • Remove the screw from the black wire of the power cord using a Phillips screwdriver. Then remove the wire.
    • Loosen the wire nut and remove the neutral wire from the power cord.
  4. Ryobi CSB135L Power Cord Replacement: paso 4, imagen 1 de 1
    • Remove the power cord from the saw.
    • To insert the replacement power cord, insert the black wire of the cord into the trigger switch and tighten the screw. Take the neutral/white wire of the new cord and insert it into the wire nut and tighten the nut.
    • Wire strippers may be needed when installing the new power cord to expose the copper wire.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 29
Todo El Tiempo: 168
