Introducción
This guide will show you how to properly replace/remove the motor housing on the Ryobi CSB135L. If the symptoms in our troubleshooting page for a malfunctioning motor or malfunctioning laser align with the symptoms your Ryobi CSB135L are experiencing, your laser or motor are most likely damaged. This guide will show you the first step in replacing them.
Qué necesitas
Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
