Saltar al contenido principal
Ryobi CSB135L Guard Replacement
Qué necesitas
  1. Ryobi CSB135L Guard Replacement, Blade: paso 1, imagen 1 de 2 Ryobi CSB135L Guard Replacement, Blade: paso 1, imagen 2 de 2
    • Remove the central 6mm hex nut and two black washers using a 6mm allen wrench.
    • Remove the old blade.
    • The blade has already been removed from this device.
  2. Ryobi CSB135L Guard Replacement, Guard: paso 2, imagen 1 de 1
    • Remove the M5 x 20 mm screw using a Phillips screwdriver.
    • Remove the black rubber stopper.
    • This allows for 360 degree rotation of the guard.
  3. Ryobi CSB135L Guard Replacement: paso 3, imagen 1 de 2 Ryobi CSB135L Guard Replacement: paso 3, imagen 2 de 2
    • Remove the four M4 x 16 mm screws holding the blade guard on using a Phillips screwdriver.
    • Rotate the guard as necessary to gain access to all the screws.
  4. Ryobi CSB135L Guard Replacement: paso 4, imagen 1 de 1
    • Remove the guard setup
    • Adjusting the blade depth to allow more room near the guard housing can help with the removal
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 146
